Hello, everyone. I have a question regarding the Micro2440SDK board. It has 2 lcd outputs, one called LCD1 and the other called LCD_A70. Can anyone tell me what must I do to make the board use the LCD_A70 output instead of LCD1? Being more detailed - I don't use the LCD touchscreen, but an LCD2VGA converter made by EmbedSky company (www.embedsky.net) called SKY_VGA. If I connect it to the LCD1 output, it works with vanilla zImages A70 and L80 (images 2011.04.21). But if I connect it to the LCD_A70 output, the screen remains black regardless of the zImage I use. Hence my question: what can I do to make it work on LCD_A70 output? Is it configurable somewhere (like in recompiling the kernel)? Or is it possible at all? I don't have any "real" 7'' LCD to connect it to the LCD_A70 output to check if it works correctly, but since the whole setup works on LCD1 output I thought it could be a configuration/driver issue. Any help would be greatly appreciated. Regards, Karach.
Micro2440SDK LCD_A70 and LCD1 interfaces
Dear sir. I have the mini2440. I need your help. For find the correct part number of connectors for use in LCD Display. The connectors of 40 and 56 contacts for use with flat cable. See attachment Or code in digikey.com Best regards. Juliano
