Hello, I try to use the 'mount' command to mount the NFS file system. Everything is worked correctly with existed NFS server. The problem occurs if I will try to connect to server which doesn't provide any NFS share (assume 192.168.2.102). After this attempt, it hangs and only sending the SIGINT signal can help. Please consider following: [root@netradio /]# mount -t cifs //192.168.2.101/nfs /sdcard/netradio/mnt -o user=piotr,pass=piotr --verbose ^C CIFS VFS: Error connecting to socket. Aborting operation [root@netradio /]# If I not send SIGINT it will hang. Is it a known issue? How can I get the connection error instead of this suspension. I use BusyBox v1.13.3 with Linux 2.6.29.4 kernel. Thank you in advance for engagement. -- Piotr Piwko http://www.embedded-engineering.pl/
