Hi...Guys... I want to measure the audio playback delay for that whether there exists any tool that is able to install on the s3c2440 board. for ex. like system monitoring tool on Linux. Please also suggest whether there is any other method in calculating the time and the cpu usage by the application when an audio file is played. Also help me in finding out the command to play audio file from command prompt Thank you surendar
audio playback command
>> Also help me in finding out the command to play audio file from command prompt You can install "mplayer" or "mad" console players. Or you can install gstreamer and play audio with "gst-launch" >>Please also suggest whether there is any other >>method in calculating the time and the cpu usage by the application when >>an >>audio file is played "Top" utility
