Hello, By configuring cURL for cross-compile, it doesn't enable SSL protocol. Is necessary cross-compile a SSL lib, that can be openssl, polarssl, gnutls, axtls, nss or cyassl. I have polarssl cross-compiled now. On the configure command, I used the option: ./configure xxxx --with-polarssl=/path/to/polarssl acordingly with the configure help, but it doesn't works, and the configure file says: checking for ssl_init in -lpolarssl... no configure: WARNING: SSL disabled, you will not be able to use HTTPS, FTPS, NTML and more. Can someone help-me? OBS: Normal compilation works normally with option --with-polarssl
