last week I buy a Mini210 and am trying to build Android using the supplied instructions and source codes. I am using Ubuntu 10.04LTS and am having the following error when compiling: ------------------------------------------------------------------------ target Static Jar: com.android.inputmethod.pinyin.lib (out/target/common/obj/JAVA_LIBRARIES/com.android.inputmethod.pinyin.lib_interme diates/javalib.jar) target Dex: Provision Could not load 'clearsilver-jni' java.library.path = out/host/linux-x86/lib make: *** [out/target/common/docs/doc-comment-check-timestamp] Error 45 make: *** Waiting for unfinished jobs.... Could not load 'clearsilver-jni' java.library.path = out/host/linux-x86/lib make: *** [out/target/common/docs/api-stubs-timestamp] Error 45 luke@android-dev-1:/opt/FriendlyARM/mini210/android/Android-2.3.1$ ^C luke@android-dev-1:/opt/FriendlyARM/mini210/android/Android-2.3.1$ clearsilver-jni clearsilver-jni: command not found luke@android-dev-1:/opt/FriendlyARM/mini210/android/Android-2.3.1$ -------------------------------------------------------------------------- Someone can help me to solve it.
Mini210 compile problem
it need to install the JDK and essential packages if you compile the android in ubuntu system. See the follow website to solve it. http://armdevs.com/wiki/index.php/Mini210:_Android:_System_Development
Sorry, The link is error, the follow link is ok: it need to install the JDK and essential packages if you compile the android in ubuntu system. See the follow website to solve it. http://minidevs.com/minidevs/info225.html
