Hi all,
When I plug a USB memory stick in my MINI2440, and try mount
it, I receive an "Invalid argument" error.
[root@ahmet /dev]# ls
1-1 root tty42
adc rtc tty43
audio rtc0 tty44
backlight sda tty45
buttons sg0 tty46
camera shm tty47
console timer tty48
[root@ahmet /dev]# mount /dev/sda /mnt
yaffs: dev is 8388608 name is "sda"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 8.0, "sda"
FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem
will !
mount: mounting /dev/sda on /mnt failed: Invalid argument
The stick is 8 GB FAT32;
if you can help me this problem,I am very happy.
Thanks in advance!
usb stick mount problem
Check first, if your kernel has support for the FAT filesystem (must be listed in '/proc/filesystems'). If not, you need a new kernel with FAT enabled, or maybe just to load a kernel module for FAS support. If yes, try to mount it with the additinal parameter "-t vfat"
thanks I used 1gb sd card now correctly mounting. I don't know why my USB(kingston 8gb) hasn't mounted. I think may not support USB or when I debugged the kernel I saw something as max 4gb supported. I don't remember exactly. another my problem . I can use gpio control in console but ı don't know to use gpio in Qt widget project. I need some tutorial and example project. other problem how I count gpio number.
