Ok, I successfully patched the kernel with all the http://www.oselas.org/oselas/bsp/pengutronix/index_en.html patches from the 2.6.38 directory. I used their kernel.config and tuned it a bit, as I don't need gfx and sound. Then I configured the kernel using xenomai 2.6.0 script prepare-kernel.sh (which patches the kernel). And the problem is that after doing that, the kernel seems to no longer support mini2440 - the ARM processor family is gone from menuconfig - Pentium PRO is checked instead. WTF? regards,
kernel patching for mini2440
This is right command line: ARCH=arm CROSS_COMPILE=<your-arm-compiler-prefix> make menuconfig Without ARCH=arm you will see X86 CPUs
