MINI2440 # fatls mmc 0:1 239636 u-boot.bin 1 file(s), 0 dir(s) MINI2440 # fatload mmc 0:1 0x31000000 u-boot.img reading u-boot.img ** Unable to read "u-boot.img" from mmc 0:1 ** MINI2440 # fatload mmc 0:1 0x31000000 u-boot.img 239636 reading u-boot.img ** Unable to read "u-boot.img" from mmc 0:1 ** MINI2440 # Any ideas what I'm doing wrong?
reading from sd
This is what I run prior fatls: MINI2440 # mmc mmc: Probing for SDHC ... mmc: SD 2.0 or later card found trying to detect SD Card... Manufacturer: 0x1f, OEM "SK" Product name: "SD2GB", revision 1.0 Serial number: 601886659 Manufacturing date: 9/2006 CRC: 0x56, b0 = 1 READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3453 size = 2329935872 SD Card detected RCA: 0x2 type: SD MINI2440 # I also tried with 64meg sd card - same result.
Boy, you are a busy chap! As per the tutorial at: http://narnia.cs.ttu.edu/drupal/node/131 u-boot was not placed on the machine with the command "fatload". Are you trying to something different?
Well I tried to follow this tutorial, but I got it all around and I'm now with uboot in NOR, and cleared NAND. How do I put uboot in NAND now? Or maybe there's a way to restore vivi in NOR?
Ok. I can read from sd. It's just a matter of filename. When I renamed it to uboot I can read it. But when I write it to nand: MINI2440 # fatload mmc 0:1 0x31000000 uboot reading uboot 239636 bytes read MINI2440 # nand write 0x31000000 u-boot NAND write: device 0 offset 0x0, size 0x40000 262144 bytes written: OK MINI2440 # And reboot from nand - nothing happens :( HELP :(
Ok. I managed to put the uboot on nand through tftpd and booted the kernel as well. Hopefully I will have something working finally!
