Hello together,
i have a problem with my tiny6410.
The bootloader won't work.
While booting the u-boot- loader i get the followng information:
U-Boot 1.1.6 (Jul 3 2011 - 22:06:17) for FriendlyARM MINI6410
CPU: S3C6410@532MHz
Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC
Mode)
Board: MINI6410
DRAM: 256 MB
Flash: 0 kB
NAND: 2048 MB
In: serial
Out: serial
Err: serial
undefined instruction
pc : [<c6e114a8>] lr : [<c7e113b8>]
sp : c7ffff24 ip : 00000011 fp : c7e60a0d
r10: c7e60a28 r9 : 00000003 r8 : 8de27559
r7 : c7e608d4 r6 : c7e2698f r5 : c7e608d4 r4 : c7ffff5c
r3 : c7e608d5 r2 : 00000062 r1 : 00000011 r0 : 00000011
Flags: nzCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
reset...
OK
While booting my screen is white, sometimes there are coloured lines on it.
I hope, you can help me....
Thomas
Problems while booting
Do you boot from NAND? If yes, it seems the uboot image in the NAND is somehow clobbered. Use the superboot bootloader to restore it.
Hi thomos, I am using the same board. using the Nand boot. I am unable to get the u-boot prompt. How did you get the u-boot prompt. Please help me -mohan
