I want to get directfb work with friendly ARM board + I
have 7" touchscreen (800x460-50Hz 16bit).
I cross compiled directfb 1.4.3 and tslib, but when I run dfbinfo I
get the following errors:
~ # dfbinfo
~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.4.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~
(c) 2001-2009 The world wide DirectFB Open Source Community
(c) 2000-2004 Convergence (integrated media) GmbH
(*) DirectFB/Core: Single Application Core. (2010-01-17 23:07)
(*) Direct/Memcpy: Using libc memcpy()
(*) Direct/Thread: Started 'VT Switcher' (-1) [CRITICAL OTHER/OTHER
0/0] <8388608>...
(*) Direct/Thread: Started 'VT Flusher' (737) [DEFAULT OTHER/OTHER
0/0] <8388608>...
(*) DirectFB/FBDev: Found 's3c2410fb' (ID 0) with frame buffer at
0x33a00000, 750k (MMIO 0x00000000, 0k)
Couldnt load module pthres
(*) DirectFB/Graphics: Generic Software Rasterizer 0.6 (directfb.org)
(!) DirectFB/FBDev: No supported modes found in /etc/fb.modes and
current mode not supported!
(!) DirectFB/FBDev: Current mode's pixelformat: rgba 5/11, 6/5, 5/0, 0/0
(16bit)
(!) DirectFB/Core/layers: Failed to initialize layer 0!
--> Initialization error!
(!) DirectFB/Core: Could not initialize 'layer_core' core!
(#) DirectFBError [DirectFBCreate() failed]: Initialization error!
fbset prints :
~ # fbset
mode "800x480-50"
# D: 23.896 MHz, H: 25.750 kHz, V: 50.000 Hz
geometry 800 480 800 480 16
timings 41848 40 40 29 3 48 3
accel false
rgba 5/11,6/5,5/0,0/0
endmode
Any idea?
Please help.
directfb with friendly ARM board
Hi, i'm trying to do the exact same thing but my problem was a "No system found" error. Can you please tell me the steps you took to compile your system. Also, a tree of your /dev directory would be helpful, as well as a list of all the configuration files you created. To port DirectFB i used the documentation in here http://free-electrons.com/docs/ Thank you, Luís Silva
Uri, I came accross this problem myself when experimenting with buserror's OE git branch. It took me a while to figure out that this error and some other errors related to illegal instructions happened because all packages are compiled with -mthumb though the kernel and modules use -mno-thumb. The mix of instruction sets seems to cause problems. A hotfix is to edit your conf/distro/include/angstrom.inc and change the line: ANGSTROM_ARM_INSTRUCTION_SET_armv4t = "thumb" to ANGSTROM_ARM_INSTRUCTION_SET_armv4t = "arm" The default for the mini2440 is -mno-thumb but for some reason (save memory space, maybe?) the angstrom distro overrides this for all armv4t family processors. After that you should rebuild your whole image. If you're building directfb apart then check if you're mixing thumb instructions and play with the -mthumb/no-thumb flag. Some libs with embedded asm may cause you trouble too. And not only directfb should be compiled with -mno-thumb but all of its dependencies as well. I had similar problemas trying to run erlang R13B04. erl gave me all sorts of illegal instruction errors and I couldn't understand the reason at the time.
I am having this problem too, I am using buildroot for my rootfs and the kernel from git://repo.or.cz/linux-2.6/mini2440.git as this kernel is the only one that I have managed to get the LED backlight to work. However I can't run any SDL with DirectFB programs and when trying to run dfbinfo it crashes like the above. Cheers Slampt
