can anyone tell me how to run gcc on mini2440 ?
Gcc on mini2440
First two posts about running GCC natively on the mini2440! School assignment? Think the first step is trying to work out how to cross compile the cross compiler. Start Googling.
I build the cross compiler using your Video but now we need to install the Gcc on the mini the problem is the mini has nothing install on it the apt-get not found the wget the gedit !!
The first question is: Why do you really want to to run a compiler on this target? This target is very slow compared to every x86 based host system. So, cross compiling is the first choice for these kind of target systems.
I need to run binary file that compiled on my host using C language i couldnt compile it using the cross compiler or write similar one i dont know what to do how to run this binary on the mini ?:(
My comment was nonsense. I think what you need to find is GCC built to run on an ARM platform, if you want to compile (natively) on the mini2440. However . . . which video are you referring to? Also, I would need a clearer picture of what you are trying to do. Dave
@Juergen no i use percompiled program written in C @davef http://www.youtube.com/watch?v=ghzRuwEAWdo this one I beleive i saw it in your old post :S i want to build speech recogantion system on the mini and all the dll and binarys i need to use is written on C and needs a C compiler i tried the cross compiler but it gave me incompatabile source when i linke to the speech librarys !? what can i do
wedyan, "pre-compiled program" means an object file (*.o)? This implies you do not have access to the source? Is it compiled for ARMv4 architecture? OABI or EABI? Which floating point format does it use? If all these settings fit to your Mini2440 root filesystem you can simply use a cross-linker to transform this object file into an executable app.
I get the configure file and i try to cross compile the package for mini2440 I use the following ./configure --host=armv4 --target=arm --prefix=/home/wedyan/Desktop/PAD/install-arm --disable-short-tags --without-mysql --with-thttpd=../../thttpd/thttpd-2.21b but i have this error :( build/temp.linux-i686-2.5/sphinxbase.o: could not read symbols: File in wrong format what can i Do ?!:(
Rename as thttpd.doc This was used to enable PHP in thttpd Maybe this will help. Also I think it should be armv4t not armv4.
Also, have you checked that you are really using the cross compiler?
./configure --host=i386-linux-gnu --target=arm \
--prefix=../install-php5 --disable-short-tags \
--without-mysql --without-pear \
--disable-all --with-thttpd=../thttpd-2.21b
Most of the time configure uses --build for your host, and --host for the
target arch. For example "--build=i686-pc-linux-gnu
--host=arm-1176jzfs-linux-gnueabi". This will trigger the cross compile
feature of the autotools.
> wrong format
Your "--host=armv4 --target=arm" still does *not* cross compile!
When I try it here (in a different package):
configure: WARNING: If you wanted to set the --build type, don't use
--host.
If a cross compiler is detected then cross compile mode will be used.
checking whether we are cross compiling... no
It cannot work this way. Configure tries a "armv4-gcc", and if it does not
exist, it falls back to non cross compile. Instead this:
./configure --build=i686-pc-linux-gnu --host=arm-1176jzfs-linux-gnueabi
checking build system type... i686-pc-linux-gnu
checking host system type... arm-1176jzfs-linux-gnueabi
checking whether we are cross compiling... yes
The configure script tries here an "arm-1176jzfs-linux-gnueabi-gcc" to
detect the cross compile case. So, it must be in the PATH.
thanx all for the help :) I just found it I used this configure ./configure --host=armv4 --target=arm --prefix=/home/wedyan/Desktop/PAD/install-arm --disable-short-tags --without-mysql CC=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc CXX=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-cpp CPP=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-cpp --without-lapack --without-python "--without-lapack --without-python" solve the problem Now its all working without the need to gcc compiler :)
"Now its all working without the need to gcc compiler :)" ?? Try taking out this line and see if it still "compiles" CC=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc
i didnt get it :( where to take this line ? i already run the binarys of the package and run them on the mini and they works fine but now im having this issue A/D library not implemented
Just to prove that you are REALLY using the GCC compiler I suggested deleting/removing this line. I am confident that your compilation will fail. In other words, you are really using the gcc compiler.
