I am facing a strange problem with the 4 wire touchscreen of the 7" display. The driver is working, it is interfaced correctly. But when I am touching the touchscreen with a stylus it is giving the correct coordinates but after I am lifting off my stylus it is still showing some reading for some time and the reading is pointing to a particular point in the screen. (not in any corner, but a constant point). Is it a hardware problem or software problem? I am not understanding. Please help me.
mini6410 with 7" touchscreen strange problem
Same here. Couldn't find the reason yet. Maybe a race in the driver (between pen up interrupt and ADC conversion ready I guess).
I am attaching some reading from the touchscreen. The touch point is around (97,425). But after lift up, I am getting the value around (340,52).
I had also some crazy behavior with my 7" Display. To solve this problem I had to move the resitors R6, R7, R8, R9 to the empty Pads of R11, R20, R21, R22. This seems to redirect the Signals from the S3C6410-ADC to a touchcontroller at the display board. After that the display worked correctly. If you want to use WinCE you have to do the following settings C:\WINCE600\PLATFORM\SMDK6410\SRC\INC\options.h set BSP_NOTOUCH= set BSP_NOTOUCH_ADC=1 set BSP_NOTOUCHCOM=1 set BSP_NOTOUCH_1WIRE=
