Hi guys, I have a Mini6410 with 7" touchscreen. I got my rootfs by ptxdist (last version OSELAS.BSP-Pengutronix-Mini6410 from git). At the end of the procedure in the images directory I have the files: u-boot, linuximage and root.jffs2. I created the SD Card boot following the procedure by FriendlyARM using the 3 files got in this way. I edited the file FriendlyARM.ini: CheckOneButton=No Action=install OS= linux VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### #Linux-BootLoader = Linux/u-boot_nand-ram256.bin Linux-BootLoader = Linux/u-boot.bin Linux-Kernel = Linux/linuximage Linux-CommandLine = root=/dev/mtdblock2 rootfstype=jffs2 init=/sbin/init console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/root.jffs2 #Linux-RootFs-RunImage = Linux/root.ext2 I powered the Mini6410, the kernel is loaded correctly, but when it starts loading the rootfs, the system fails. Download bootloader... Download bootloader succeed Download kernel... Download kernel succeed Download yaffs-image ... Download yaffs-image failed Why this happens, in Linux-CommandLine I edited rootfstype=jffs2. I tried to setup yaffs rootfs in platformconfig of ptxdist, but it's not possible. Could someone help me?
Boot problem Mini6410 with image by Pengutronix BSP
I managed to create the rootfs yaffs2 mkyaffs2image through the tool-128M. Now both the kernel and the rootfs are loaded into Flash. Unfortunately when I boot the system from NAND it gives me this error: Creating 3 MTD partitions on "nand": 0x000000000000-0x000000100000 : "uboot" 0x000000100000-0x000000300000 : "kernel" 0x000000300000-0x000040000000 : "rootfs" dm9000 Ethernet Driver, V1.31 eth0: dm9000a at d085c000,d085e004 IRQ 108 MAC: 08:90:90:90:90:90 (chip) input: gpio-keys as /devices/platform/gpio-keys/input/input0 samsung-ts s3c64xx-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input1 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c64xx-rtc: rtc disabled, re-enabling s3c-rtc s3c64xx-rtc: rtc core: registered s3c as rtc0 TCP cubic registered VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 s3c-rtc s3c64xx-rtc: setting system clock to 2011-10-29 02:13:35 UTC (1319854415) VFS: Cannot open root device "mtdblock2" or unknown-block(31,2) Please append a correct "root=" boot option; here are the available partitions: 1f00 1024 mtdblock0 (driver?) 1f01 2048 mtdblock1 (driver?) 1f02 1045504 mtdblock2 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2) [<c002ae38>] (unwind_backtrace+0x0/0xe4) from [<c021fc4c>] (panic+0x68/0x180) [<c021fc4c>] (panic+0x68/0x180) from [<c0008cdc>] (mount_block_root+0x1b8/0x1f8) [<c0008cdc>] (mount_block_root+0x1b8/0x1f8) from [<c0008dbc>] (mount_root+0xa0/0xc0) [<c0008dbc>] (mount_root+0xa0/0xc0) from [<c0008ef8>] (prepare_namespace+0x11c/0x17c) [<c0008ef8>] (prepare_namespace+0x11c/0x17c) from [<c0008944>] (kernel_init+0xe4/0x118) [<c0008944>] (kernel_init+0xe4/0x118) from [<c0026594>] (kernel_thread_exit+0x0/0x8) What's the problem? my Linux-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
If you are using the kernel from my BSP, there is still no support for the NAND in it. That's why it *must* fail. Development for the Mini6410 happens slowly on my side...
Thanks Jurgen, does the kernel from your BSP support SDCARD ? If yes, what's the Linux-CommandLine I do in ini file? Or can you explain me what's the procedure to boot the system when I obtain u-boot, linuximage and root.tgz? Thanks in advance.
