how to edit bashrc in mini2440 ?? i want to set a path i use export PATH=.... but i dont know if the bashrc saves the change thanks for any reply . nadia
Are you talking about linux or in the Android system? If it's in Linux, you must open the file as root. For example, in Ubuntu, you would do: sudo gedit ~/.basrc and the add the changes you want. Then press CTRL+S and the file will be saved. To look at the file do: more ~/.bashrc Good luck! -S
Hi nadia, it depends on your linux distro, In the rootfs in the CD, you can set PATH at: /etc/init.d/rcS
well, 1. install nano or mc (midnight commander) 2. pull the file on your computer, edit, push it back... 3. configure a ftp server, and edit the file in place.. have fun, Zogzog.
