Hi, Anyone has any idea of the maximum number of write cycles of NAND used in micro2440? TIA Vikas
any idea of # of write cycles of NAND in micro2440
Dear Lalitha, I hope I am working on NAND flash as NAND flash is used in my board. From the manuals I found that it has 1M write cycles max. I also hope that you know bad blocks are developed in NAND flash when you keep writing it. The similar types of chips are in SSDs. So i resolved this by putting my root file system on SD Card. Now i need not worry about write cycles in my NAND flash. Regards, Vikas
Dear Lalitha, I agree that the limitation of write cycles applies to SD CARD too. But replacing SD CARD after failure is much easier and cheap. Regards, Vikas
Atcually I am trying put my application in NAND Flash but the application hangs up in the middle itself but same application runs fully in SDRAM why is this difference? if u know plz. highlight on this Regards, Lalitha
Lalitha, You have to tell me details of your application. Which OS you are using? How that application is compiled? which boot loader and kernel you are using? Regards, Vikas
See I have compiled complete application using ADS1.2 and its size is about 1.9MB and I am using supervivi boot loader which come along with the kit
This should work without any problem. As replied in other post, boot from NOR and then download and run. That will download the application to NAND and run from there.
