console login
Micha
sorry if this is a dumb question but I am fairly new here...  Is there a
way to require users to provide user/password when connecting via RS232
console?
sean_h
passwd (followed by enter key on console)
Micha
if by that you mean to use passwd to set the root password (as it is blank
by default), I have done so. This will work for telnet and ftp, however I
can still log on using my serial port without being prompted for
anything...and have full root privileges that way :-(
Juergen Beisert
You should run any of the known login tools on your serial line. (agetty or
similar). This kind of programs will send a greeting and waits for user
name and password.
Micha
I am working of the factory (qtopia) rootfs. Turns out that busybox uses
some defaults, if it can't find /etc/inittab (which doesn't exist). So my
solution was: Create /etc/inittab like this:
::sysinit:/etc/init.d/rcS
::respawn:/sbin/getty -L ttySAC0 115200 vt100
::restart:/sbin/init
::ctrlaltdel:/sbin/reboot
::shutdown:/bin/umount -a -r
::shutdown:/sbin/swapoff -a
