Hello, I just installed WinCE into my Tiny6410 but having problems with the touchscreen i.e. not working. I had to plug a mouse into the USB to move the cursor. Another issue, I have installed Android previously before WinCE but I want to be able to revert back to Android. I have copied the image to flash as before and change the friendlyarm.ini to install android but nothing happens. No buzzer or LED flashing as though it isn't booting into SD card. The dipswitch is set to SD-BOOT. The SD has already been fuse with superboot.bin as I have already used it for installing android previously and now WinCE. When I plug into the DNW with dipswitch set to nand, the bootloader used for WinCE is Nboot from the serial output. Could that be the problem? Regards Paul
WinCE problem
Not the most responsive forum. So much for the support. What is the purpose of calling it FriendlyArm when it isn't well supported. Possibly should have went for Gumstix or Beagleboard as they would have a larger user base.
