change login message
user
hi
when I telnet to mini2440, I see the following lines
Kernel 2.6.32.2-FriendlyARM on (/dev/pts/0)
feriendlyARM login: root
Password:
[root@FriendlyARM /]#
how can I change the above welcome lines?
b.r.
Micha
The first line is the kernel version, you can change the "-FriendlyARM" if
you recompile the kernel image (it comes on the CD): with "make menuconfig"
go to "General Setup" and then "Local version". It will let you enter that
text string.
The "friendlyARM" before the login is the host name. You can change it in
one of the first lines in the /etc/init.d/rcS file.
