Hi! I've bought mini6410 with lcd2vga board. Everything works fine with linux 2.6.26, but video mode. It seems vga board is working in 16k color mode and pictures are ugly, especially, gradients. I've tried to pass different framebuffer modes to kernel like vga=mode, unfortunately it didn't change anything. So, am I doing anything wrong, or lcd2vga can't work in different mode?
lcd2vga board video mode
Okay, so it is a 64 k true colour mode (RGB565). This is the default colour depth the board file sets up for the driver. I don't know your 2.6.26 kernel. In recent Linux kernels (3.1) you can change it in the "linux/arch/arm/mach-s3c64xx/mach-mini6410.c" board file, search for structure "s3c_fb_pd_win" and its member ".default_bpp".
Thanks for help. I've changed .default_bpp as you suggested. But with no effect. All things seems to be ok, except gradients. Every picture has gradient looks not good.
The full 24 bit RGB888 data are available at the connectors LCD3 and LCD2. Maybe the pins at the CPU are not full configured to support 24 bits per pixel. In recent kernels the function "s3c64xx_fb_gpio_setup_24bpp()" exists to setup all required pins. Do you still use the 2.6.26 kernel? Is a function like this existing in your kernel?
I've downloaded linux-2.6.36 from friendlyarm.net and use this kernel. I didn't found "s3c64xx_fb_gpio_setup_24bpp()" in "linux/arch/arm/mach-s3c64xx/mach-mini6410.c" file. Just ".setup_gpio = s3c64xx_fb_gpio_setup_24bpp" in "s3c_fb_platdata mini6410_lcd_pdata __initdata" structure. So, should I get the newer kernel? Thanks!
Ok, but an "linux/arch/arm/mach-s3c64xx/mach-mini6410.c" is specific for mini6410 board, isn't it? And, as I understand, there isn't it file in kernel tree.
Yes, the "arch/arm/mach-s3c64xx/mach-mini6410.c" file is the so called board file and does the specific setup for the Mini6410 board. And this file is part of the plain vanilla linux kernel. As of today: > ls -l arch/arm/mach-s3c64xx/mach-mini6410.c -rw-r--r-- 1 jb user 8264 Oct 7 12:10 arch/arm/mach-s3c64xx/mach-mini6410.c
I've tried vanilla kernel 3.1-rc9 as you suggested. The "linux/arch/arm/mach-s3c64xx/mach-mini6410.c" board file is the same as my one in linux-2.6.36. And there isn't "s3c64xx_fb_gpio_setup_24bpp()" function in that file.
So, if you have that function in your "linux/arch/arm/mach-s3c64xx/mach-mini6410.c" board file, could you send me this file, please? Thanks!
I just did a "git pull" here, opened the file "arch/arm/mach-s3c64xx/mach-mini6410.c" and found in line 183 the call to the "s3c64xx_fb_gpio_setup_24bpp()" function.
Well, when I set CONFIG_S3C64XX_SETUP_FB_24BPP=y in kernel .config file, /dev/fb0 even doesn't create after booting.
When I enable board support for the Mini6410, CONFIG_S3C64XX_SETUP_FB_24BPP is always enabled due to the "select S3C64XX_SETUP_FB_24BPP" in arch/arm/mach-s3c64xx/Kconfig, line 110. So, I don't know what you are doing.
