Hi I have mini 2440 running Android (kernel 2.6.27) on it. When I plug-in USB drive, the drive is detected and I get the following output on the dmesg. scsi 0:0:0:0: Direct-Access Kingston DataTraveler II PMAP PQ: 0 ANSI: 0 CCS sd 0:0:0:0: [sda] 2014208 512-byte hardware sectors (1031 MB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Assuming drive cache: write through sd 0:0:0:0: [sda] 2014208 512-byte hardware sectors (1031 MB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Assuming drive cache: write through sd 1:0:0:0: [sda] Attached SCSI removable disk I'm also able to see the device under /sys/block/sda. But I'm not able to mount the USB drive (mount -tvfat /dev/sda /mnt fails) as there is no device in the /dev/sdaX. Does any one know how to fix this issue?
Unable to mount USB drive
Seems your kernel support for USB mass storage devices is incomplete. Maybe you just need to load the required kernel modules or you must re-configure and re-compile your kernel.
Thanks. Do you know what kernel module needs to be added? Based on my google results, it looks like udev is the missing piece here. Can you clarify?
My fault: You already wrote you see the "/sys/block/sda". So it seems the kernel works correctly. If you are using static devicenodes, just create the missing devicenode. Or run (you already found it) "udev" to do this job for you.
Juergen, Thanks a lot. I just created nodes for sda / sda1 and it worked. You have been very helpful.
