Hi, I am working on s3c2440 ARM linux platform. I am connecting an image sensor device to the camera controller of the s3c2440 ARM processor. The image sensor outputs YCbCr 4:2:2 output. Can I pass the output of this format to the preview path of the camera controller to get proper image ? The image sensor also outputs RGB565 format, which I can comfortably view using the preview path. But I would like to get the YCbCr 4:2:2 format from the image sensor device. Is this possible with the preview path ? Any other register settings are required for YCbCr 4:2:2 mode on the preview path, other than that done for the RGB565 format. ? Thank You GIGIN
