I once had an example script for Qt fluidlauncher demo that would run ts_calibrate only when it has not been calibrated. After it has been calibrated it will execute the app only. I cant find this script anywhere. Does someone know how to check if tslib has been calibrated or not?
run ts_calibrate only when not calibrated
i use it like this (in my startupscript which starts the qt app)
if [ -f /etc/pointercal ] ; then
$QPEDIR/myAPP -qws
else
ts_calibrate
$QPEDIR/myAPP -qws
fi
Just check the file qt4 in /bin/qt4. It's the demo script to run
fluidlaucher.
[root@FriendlyARM /home]# ls -l /bin/q*
-rwxr-xr-x 1 root root 829 Aug 16 2010 /bin/qt4
-rwxr-xr-x 1 root root 823 Mar 30 2009 /bin/qtopia
[root@FriendlyARM /home]# vi /bin/qt4
#!/bin/sh
export TSLIB_TSDEVICE=/dev/input/event0
export TSLIB_CONFFILE=/usr/local/etc/ts.conf
export TSLIB_PLUGINDIR=/usr/local/lib/ts
export LD_LIBRARY_PATH=/usr/local/lib
export PATH=/bin:/sbin:/usr/bin/:/usr/sbin:/usr/local/bin
export QWS_DISPLAY=:1
TS_INFO_FILE=/sys/devices/virtual/input/input0/uevent
if [ -e $TS_INFO_FILE -a "/bin/grep -q TouchScreen < $TS_INFO_FILE" ]; then
export QWS_MOUSE_PROTO="Tslib:/dev/input/event0
MouseMan:/dev/input/mice
if [ ! -s /etc/pointercal ] ; then
rm /etc/pointercal
/usr/local/bin/ts_calibrate
fi
else
export QWS_MOUSE_PROTO="MouseMan:/dev/input/mice"
fi
unset TS_INFO_FILE
Regards
