Hi, I have a laptop running with vista on it. I am trying to connect the mini2440 board to VS2005 Pro. But couldn't. I did the following steps as mentioned on the http://www.domodom.fr/spip/Generer-une-image-Windows-CE-pour.html?lang=en. Visual Studio 2005 Pro Windows Embedded CE 6.0 the service pack 1 of Visual Studio 2005 Pro the update for Vista if you use Vista the service pack of Platform Builder 6.0 The R2 & R3 revisions of Windows Embedded CE 6.0 I have also followed the link http://www.domodom.fr/spip/Ma-premiere-application-sous.html?lang=en. I installed the DNW usb driver but i cann't see [USB:OK] on DNW window rather i get [USB:x] all the time though i have changed the USB download address: 0x30000000. I can get into NOR Flash by connecting serial cable rs232 but again cann't download anything via USB host. The board cann't connect to USB host. I couldn't able to install Active Sync on my vista based machine. Then i tried windows mobile device center for synchronization; but cann't find the board. BTW wat is the difference between wince 6.0 and platform builder 6.0. As in the installation process we install Wince6.0 and then later we install Platform Builder service pack 1. I will highly appreciate if someone help me out here... Kind Regards Naveed
Connection Problem between Mini2440 and VS2005 Pro
Hi, Can someone please elaborate with some detail the following two lines... following from the link http://www.domodom.fr/spip/Ma-premiere-application-sous.html?lang=en "That’s time to turn on mini2440, connect USB cable and verify that Activesync is OK. We can press F5 to launch generation, deployment and launch our application on mini2440." Cann't use Active Sync and Cann't connect to the board. Can anyone discuss on the "Target" and its settings option on the menu of VS2005 pro installed with wince 6.0 Many thanks Kind Regards Naveed
my board mini 2440 don´t syncronize with activesync what i do.?Just connect as guest. windows ce 6.0 windows xp.
