Hello, I'm using mini2440 and I would like to know the maximum transfer rate of the pins GPIO input. THANKS FOR YOURS ANSWERS.
transfer rate
@Michael: how did you run GPIO at 700K byte/s? i've test with shell script
to blink the led as follow:
#!/bin/sh
# Blink the onboard LED
GPIO=$1
cleanup() { # Release the GPIO port
echo $GPIO > /sys/class/gpio/unexport
exit
# Open the GPIO port
echo $GPIO > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio$GPIO/direction
trap cleanup SIGINT # call cleanup on Ctrl-C
# Blink forever
while [ "1" = "1" ]; do
echo "1" > /sys/class/gpio/gpio$GPIO/value
echo "0" > /sys/class/gpio/gpio$GPIO/value
done
cleanup # call the cleanup routine
When i measured with oscilloscope it said only 650~ Hz,
What am I wrong?
