I've bought an mini6410 board with preinstalled WinCE. Unfortunately, there is no u-boot. How can I flash u-boot into NAND?
u-boot flashing in mini6410
You need a computer with windows installed for this way: - Use the SD-FLASHER(windows) and burn a uboot for SD.bin on it - Switch to SD Card boot and start the mini6410 from the flashed sd - format nand in uboot, upload uboot for nand.bin with DNW (windows) or dnw2 / xdn(linux)
When I try to burn u-boot onto SD card, choosing u-boot.bin file, SD-flasher says: "Error: unrecognizable file".
I've also tried the same procedure with superboot. SD-flasher says that all things are ok. But, when I try to boot mini6410 from sd card, nothing happens.
Thanks for advices. The problem was just in SD card. When I tried another one, all became work. I don't understand is that a bug in bootloader or in hardware.
