When I run ts_calibrate or an application I made, when I click on my app, the click is also processed by Qtopia in the background, is there a away to avoid this? I notice that the recalibrate app (native to Qtopia) for example makes the Qtopia to shutdown removing it from the background so ts_calibrate runs properly
Qtopia Question
It sounds like you have discovered how to make an icon and click on it. Are you using Qcreator? In this case, wouldn't you want Qtopia to process your click and run your application? I don't understand what you mean by clicking on your application (in the foreground and on what?) and having Qtopia process it in the background. I run my application from bash, with Qtopia in the background (I guess) and it runs OK.
I did a simple window on QtCreator , when i run the app -> ./hellogui -qws , if i click any place of the hellogui window, the click is also processed by the background, that in this case is QTopia. I want Qtopia to process a click only when app is closed, similiar to native qtopia apps.
