I plug my usb wifi adapter and I had compile the kernel with the zd1201
driver I know because I seen the file zd1201.o being created.
but when I plug the USB WIFI, I get this error, what is the hotplug
firmware loader?, and how can I instal it?
[root@FriendlyARM /]# usb 1-1: new full speed USB device using s3c2410-ohci
and2
usb 1-1: New USB device found, idVendor=0ace, idProduct=1201
usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
usb 1-1: Product: USB WLAN
usb 1-1: configuration #1 chosen from 1 choice
usb 1-1: firmware: requesting zd1201.fw
usb 1-1: Failed to load zd1201.fw firmware file!
usb 1-1: Make sure the hotplug firmware loader is installed.
usb 1-1: Goto http://linux-lc100020.sourceforge.net for more info.
usb 1-1: zd1201 firmware upload failed: -2
zd1201: probe of 1-1:1.0 failed with error -2
fail to load wifi driver, hotplug missing?
I activated the hotplug on the kernel and now I'm getting this, but still not working usb 1-1: new full speed USB device using s3c2410-ohci and address 2 usb 1-1: New USB device found, idVendor=0ace, idProduct=1201 usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 usb 1-1: Product: USB WLAN usb 1-1: configuration #1 chosen from 1 choice Compat-wireless backport release: compat-wireless-2011-01-06 Backport based on linux-next.git next-20110111 cfg80211: Calling CRDA to update world regulatory domain usbcore: registered new interface driver ath9k_hif_usb kfifo: module license 'unspecified' taints kernel. Disabling lock debugging due to kernel taint usbcore: registered new interface driver rt73usb usbcore: registered new interface driver rt2800usb usbcore: registered new interface driver zd1211rw
I got the drivers installed and is connected to the router but still not
working this is what I did, what am I missing? I try to ping from my
computer and use Konqueror but nothing :(
[root@FriendlyARM /]# iwconfig wlan0 ssid leds_lan
iwconfig: unknown command "ssid"
[root@FriendlyARM /]# iwconfig wlan0 essid leds_lan
[root@FriendlyARM /]# iwconfig wlan0 192.168.1.230 netmask 255.255.255.0
iwconfig: unknown command "192.168.1.230"
[root@FriendlyARM /]# ifconfig wlan0 192.168.1.230 netmask 255.255.255.0
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11b ESSID:"leds_lan" Nickname:"zd1201"
Mode:Managed Channel:6 Access Point: 00:17:3F:83:12:4C
Bit Rate:11 Mb/s
Retry RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality:0/128 Signal level=76/128 Noise level:0/128
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
guys I'm still curious why the wifi is connected but not transmitting data,
anyone has any idea?
[root@FriendlyARM /]# iwconfig wlan0 essid belkin
[root@FriendlyARM /]# ifconfig wlan0 192.168.1.115 netmask 255.255.255.0 up
wlan0 IEEE 802.11b ESSID:"belkin" Nickname:"zd1201"
Bit Rate:11 Mb/s
Encryption key:off
Link Quality:0/128 Signal level=69/128 Noise level:0/128
[root@FriendlyARM /]# ping 192.168.1.2
PING 192.168.1.2 (192.168.1.2): 56 data bytes
