NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V
8-bit)
Bad block table not found for chip 0
Scanning device for bad blocks
Bad eraseblock 4236 at 0x000021180000
Creating 5 MTD partitions on "NAND 1GiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "supervivi"
0x000000040000-0x000000060000 : "param"
0x000000060000-0x000000560000 : "Kernel"
0x000000560000-0x000040560000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V
8-bit" -- size truncated to 0x3faa0000
0x000000000000-0x000040000000 : "nand"
>> ubiformat /dev/mtd3 -y -e 0
ubiformat: mtd3 (nand), size 1068105728 bytes (1018.6 MiB), 8149
eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
libscan: scanning eraseblock 8148 -- 100 % complete
ubiformat: 8144 eraseblocks are supposedly empty
ubiformat: 5 bad eraseblocks found, numbers: 4193, 8145, 8146, 8147, 8148
ubiformat: use erase counter 0 for all eraseblocks
ubiformat: formatting eraseblock 8148 -- 100 % complete block 2397 -- 29 %
complete
>> ubiattach /dev/ubi_ctrl -m 3
UBI: attaching mtd3 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 129024 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 512 (aligned 512)
UBI: data offset: 2048
UBI: max. sequence number: 0
UBI error: ubi_read_volume_table: the layout volume was not found
ubiattach: error!: cannot attach mtd3
error 22 (Invalid argument)
ANY IDEA?
