Has anybody tried it?
Sharp 4.3 LCD for mini6410
The "N43" display unit comes with a 4.3" NEC NL4827HC19-01B. Do you ask about the "N43i"? Or what name does the display unit with the Sharp TFT uses?
My N43i unit also uses NEC NL4827HC19-01B. But i haven't succedded in making it normally working, even by replacing jumpers. So i'd like to buy a sharp LCD and i am interested if it can be directly connected to mini6410 or it needs a panel like N43.
AFAIK now the Sharp display is of type "LQ043T3DX02". But I wonder about your LCD: it is the same as mine and does not work. There seems something other different in the display unit than only the touch control.
it has NL4827HC19-01B inside. And it is connected to N43i module. I can make a photo of my N43i module.
