Following is the simplest of all, and its not working.
No LED blinks , i even tried while loop on ioctl as to keep it open
to monitor, i am working mini2440. Anybody please suggest me.
It got build at PC i transfer the binary to taget but led is not blinking
plz help
int main()
int on;
int led_no;
int fd;
fd = open("/dev/leds0", 0);
if (fd < 0) {
fd = open("/dev/leds", 0);
if (fd < 0) {
perror("open device leds");
exit(1);
ioctl(fd, 1, 1);
close(fd);
return 0;
simple program
The first thing to check is do you actually have a /dev/leds0 and a /dev/leds What do you get when you cat those files?
well i dont have led0 but i have leds under dev directory of target. here is paste: [root@FriendlyARM /dev]# ls adc random tty42 audio root tty43 backlight rtc tty44 buttons rtc0 tty45 camera shm tty46 console timer tty47 controlC0 tty tty48 cpu_dma_latency tty0 tty49 device tty1 tty5 dsp tty10 tty50 fb0 tty11 tty51 full tty12 tty52 i2c tty13 tty53 input tty14 tty54 kmsg tty15 tty55 leds tty16 tty56 log tty17 tty57 mark leds .. looking for reply ! thanks devfs
hello vib, well i did changed it to leds only but still no success. i do get binary and run it on target like: ./ledtesting but i dont see any affect on LED 1, btw on mini2440 4 leds keep on running ..looks like a count to me please help
That's because when you boot up the standard distro that FriendlyArm supplies there is a little leds utility running. Think you have to stop that program running then try running your program. Look in /etc/rcS and comment out the line referencing the LED app.
Hello Davef I got it working led2 , now it dont blink. Thanks a lot 1 more thing , how to change the boot up logo i mean the linux logo? Do you have any idea how to change or replace it?
