Hi! I'm using mini6410 with selfmade rootfs. ts_calibrate and ts_test work fine, but when i launch qt application, i can't use touchscreen :( I configured qt with the following options: -silent -force-pkg-config -opensource -confirm-license -largefile -no-qt3support -depths 8,16,32 -qt-gfx-linuxfb -no-gfx-transformed -no-gfx-qvfb -no-gfx-vnc -no-gfx-multiscreen -no-gfx-directfb -no-mouse-pc -no-mouse-linuxtp -qt-mouse-linuxinput -qt-mouse-tslib -no-mouse-qvfb -D QT_NO_QWS_CURSOR -no-kbd-tty -qt-kbd-linuxinput -no-kbd-qvfb -release -shared -little-endian -embedded arm -no-gif -no-libmng -qt-zlib -no-libjpeg -no-libpng -no-libtiff -no-freetype -no-openssl -qt-sql-sqlite -no-xmlpatterns -multimedia -audio-backend -no-phonon -no-phonon-backend -no-svg -no-webkit -no-script -no-scripttools -no-javascript-jit -no-stl -no-declarative -no-gfx-qnx -no-kbd-qnx -no-mouse-qnx -no-xinerama -no-cups -no-nis -no-accessibility -no-separate-debug-info -prefix /usr -plugindir /usr/lib/qt/plugins -fast -no-rpath I aloso made "export QWS_MOUSE_PROTO=tslib:/dev/touchscreen-1wire" The method "ts_read_input" from tslib plugin "input.so" is called when i touch screen in the running qt-application (in -qws mode), but i get no reaction from application. Hope you will help me, __ Best Regards, Anna Rassudova
QT 4.7.3 - Touchscreen inactive
I can even drag cursor in the application. But it is very slow. And when i click on application controls (for example buttons) nothing happens
What data protocol your "/dev/touchscreen-1wire" provides? Does it match with one of the supported protocols of the tslib?
Hmm, then it seems your tslib configuration is okay. With the internal ADC driver for the touchscreen of my Mini6410 is works (it reports the touch events via the input event subsystem). Sorry, no idea what is causing your trouble.
