hi to all, I have some sd boot problems with my tiny board (2G Nand flash) at the end the boot looder doesen't work and no led1_flushing at all. (tested using win xp or win7_administrator_relayout etc) questions: 1) it is not clear for me the structure of sd card. The user manual report /images/linux/(all file on DVD /linux image including superboot) and /images/Friendlyarm.ini Reading the .ini file (superboot_20110722) it report only /linux/ Question: can you give to me the right answer? or post to me superboot/flasher/and 2) can I run Linux (not ubuntu) from sd using Action=run? In addition: I have the same problem using sdflasher v1022 or 1120 (tested on 3 different sd card 2/4/16G and all reports no error) and different bootlooader (superboot-20110527.bin, superboot-20101223.bin, superboot-20110722.bin, superboot-20110727_beta) using /image/linux or /linux tree --------below my FriendlyARM.ini ----- #This line cannot be removed. by FriendlyARM(www.arm9.net) LCD-Mode = Yes LCD-Type = N43 CheckOneButton=No Action=run OS= linux VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = superboot-20110727.bin Linux-Kernel = Linux/zImage_n43 Linux-CommandLine == root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4-mlc2.ubi Linux-RootFs-RunImage = Linux/rootfs_qtopia_qt4.ext3 ################### Android #################### etc etc...... thanks in advance for any support
tiny6410-boot sd problem
1) I got two DVDs, DVD 2 has all the images as it should. 2) I think it should work, I haven't tried it myself. To prove that your images/system is working, use "install", and that I have tried. It works.
thanks for your fast reply I've used the DVD2 for the image but my problem is that I'm not able to boot the board via SD using superboot any suggestion?
1.Make sure you use sdflasher to initialize the SD card. 2) Use "install" if it works 3) Connect a serial cable and use hyperterminal to check the SD reading status.
Hi , I tried install Linux/Android from SD card using superboot_20110722.Please copy "superboot-20110727.bin" to "Images/Linux" or "Images/Android" folder and change your Friendlyarm.ini like "Linux-BootLoader = Linux/superboot-20110727.bin" "Android-BootLoader = Android/superboot-20110722.bin" It works well.
thanks for the answer I will try as you suggest! My real problems seam related to superboot and sd card. Without any configuration (just fuse) the superboot doesen't start I have tried different sd card and readers but I'm not able to work properly. the sd is well formattetd (two partions, as described in the manual) no error everythins seams ok but the card doesen't start!! When I fuse the sd card using uboot_sd_nand256 every things is ok but using DNW I can transfer only uboot and image_n43 all the other transfer will fail (remaing locked at 90% and I have to reboot)
