when I start up my mini2440 I see Starting Networking Starting Webserver Starting Led Starting Qtopia whats the file the loads all those applications?
loading applications
thank you I wanted to start the streamer when I start the mini2440 and I though by adding this line to rc.S would do it /mjpg-streamer/start_uvc.sh but didn't work :( any ideas what can I do?
yes it is and it executes, but you can see what happen. when it boots, then I press enter and I can run the program without any problems --------------------------------- Try to bring eth0 interface up......eth0: link down Done /mjpg-streamer/start_uvc.sh: line 30: ./mjpg_streamer: not found Please press Enter to activate this console. eth0: link up, 100Mbps, full-duplex, lpa 0x41E1 [root@FriendlyARM /]# cd mjpg-streamer/ [root@FriendlyARM /mjpg-streamer]# ls LICENSE mjpg_streamer start_uvc.sh input_s3c2410.so output_file.so start_uvc_yuv.sh input_testpicture.so output_http.so www input_uvc.so start_s3c2410.sh [root@FriendlyARM /mjpg-streamer]# ./start_uvc.sh MJPG Streamer Version.: 2.0 i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 5 i: Format............: MJPEG o: www-folder-path...: ./www/ o: HTTP TCP port.....: 8080 o: username:password.: disabled o: commands..........: enabled
I added this lines in the rc.S and it works!!! export LD_LIBRARY_PATH="$(pwd)" /mjpg-streamer/mjpg_streamer -o "/mjpg-streamer/output_http.so -w ./mjpg-streamer/www" -i "/mjpg-streamer/input_uvc.so " is there a cleaner way to do it?
