Hi All I have a project that requires a Web front end to configure the settings. I have http working from the mini2440 Does any one know of a web front end for configureing the board that i can use as a starting point i need to be able to change IP and a few other bits I have googled a bit but cant find anything Thanks for your help Colin
Web Configuration
Colin, I have cross-compiled thttpd with PHP enabled using the Pengutronix toolchain. I have a HowTo for that little task. All that is missing is getting the web page to modify target settings. I currently use a html page and the Submit button to control a uP. But, it's written in C and I want something to modify "on the fly" hence PHP. Dave
Hi, I have started to work on this some times ago, but couldn't go very far. I didn't found some php framework light enough (both in learning curve as well as in number of files involved) so i started my own web interface. Attached what i have done so far. If i remember well, you can configure ip adress and that's about all. unzip in your www folder and point your browser to webif/config.php Hope you can do something with it, Laurent
Hi Thanks for your posts very helpful Laurent thanks for sharing your source i will have a play with it and post back any results Best regards Colin
In your opinion, what is the best web browser for embedded devices? I have some friends using the apache. I need a web server which could be capable of running php modules, and javascript functions. Davef, could you send the HowTo you made? Thanks, Andre.
Re-name as a .doc file. Don't know about Javascript. Lots of hits on Google, seems it can do some Javascript stuff. For a web browser I use the demo/browser that comes with Qt. Good enough for my needs. Dave
Have you looked into LuCI? http://luci.subsignal.org/ OpenWRT uses it as main config-interface. It's pretty extensible, themeable and comes with almost everything one might need (from small-scale to full blown webif) It runs on pretty any web server, all it needs is the lua-bindings and fastcgi if I remember correctly.
