Hi, I have 1GB Nand mini2440. I don't know configure uboot for 1GB NAND board. I didn't get any information on Net. So can any one please help me regarding this. --dwnlds
About U-Boot for 1GB NAND Mini2440
I'm in! I tried several tutorials to do that and I can't get it working. If someone knows how to do it please post it. If I find everything that work I'll tell you guys.
U-boot is a bootloader. It just starts up the mini2440 and needs to boot something else - either from nand, mmc or the network. What are you trying to boot and where is it? There are tone of tutorials to set up u-boot for open embedded over mmc and tftp for u-boot this one is good http://code.google.com/p/mini2440/wiki/MiniBringup and this one is for another bootloader (you can read it for some bootloader funda) http://wingston.workshopindia.com/wingz/baby-steps-with-the-mini2440-boo...
And if you do need help this forum provides excellent support on u-boot http://billforums.station51.net/viewforum.php?f=1
Thank you very much for your quick reply! I'll be testing it and I'll let you know how it was. And by the way, have a happy new year
Wingz, I tried the forum you posted but with no success. I compiled u-boot and then uploaded it from supervivi to several ram position acording various tutorials (like 0, 0x33f80000, 0x32000000, 0x31000000) but everytime I execute go <mem position> it get stack. If I turn the switch to nand position and boot the board I've got the u-boot menu, but it get stacked when I execute "nand createbbt". I'm a little bit lost at this point. If you can give me some clues I'll appreciate it. Thanks.-
nand createbbt can take ages on the 1gb mini2440. :D 20 - 25mins is what it usually takes..don't worry.. its not stuck! just keep the nand createbbt command running till it completes..
everything worked fine while i was executing uboot in ram, but after copying it into flash, and booting the board in nand flash mode, the board is sending junk at serial, and no booting is taking place ????? what's wrong with the u-boot !!!!!!!!!!! help :(
Have a look around: http://billforums.station51.net/ the topic was covered there. Oops, I see it is already mentioned above so you have probably seen all that stuff already. There are other solutions, unless you really want to use u-boot.
http://www.friendlyarm.net/forum/topic/662 or maybe a thread in the 10 pages of hits for <1gb nand>
