1) make without specifying CROSS_COMPILE wikibuntu@wikibuntu:~/compile_kernel/KERNEL$ sudo make [sudo] password for wikibuntu: make: arm-linux-gcc: Command not found CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s /bin/sh: arm-linux-gcc: not found make[1]: *** [kernel/bounds.s] Error 127 make: *** [prepare0] Error 2 2) make with specifying sudo make CROSS_COMPILE=/opt/FriendlyARM/toolschain/4.5.1/bin/arm-none-linux-gnueabi- ARCH=arm -j4 My question is, I have CROSS_COMPILE AND ARCH environment variables setup on bash.bashrc under etc folder. In Terminal when I type arm-linux-gcc it works. However, when running the make, it says, 'command not found' Strangely, on folder where the source from FriendlyARM resides, It can see the arm-linux-gcc. Hence no error generated. Any idea why? Cheers! vib
setting up env variables
In Terminal when I type arm-linux-gcc it works. Do you mean it echos the arm-linux-gcc version? Better show us what you put into bash.bashrc.
