plz help me on it.....
Mini2440 S3C2440 Features
• SDRAM Memory
64 MB SDRAM
• FLASH Memory
1GB Nand Flash
• LCD
Company : NEC 3.5
the following is the terminal output:
mmc: Probing for SDHC ...
===============> MMC CMD Timeout
mmc: No answer to CMD8 trying SD
trying to detect SD Card...
Manufacturer: 0x1b, OEM "SM"
Product name: "SD ", revision 1.0
Serial number: 3914402499
Manufacturing date: 5/2008
CRC: 0x00, b0 = 1
READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3453
size = 2329935872
SD Card detected RCA: 0xb368 type: SD
2060420 bytes read
## Booting kernel from Legacy Image at 31000000 ...
Image Name:
Created: 2010-03-26 5:54:15 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2060356 Bytes = 2 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
done, booting the kernel.
Linux version 2.6.27 (root@tom) (gcc version 4.3.2 (Sourcery G++ Lite
2008q3-72) ) #1 PREEMPT Mon Aug 24 17:01:35 CST 2009
Machine: FriendlyARM Mini2440 development board
CPU S3C2440A (id 0x32440001)
MM: CPU does not support supersection mapping for 0x55000000000 at
0xf0d00000
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: console=ttySAC0,115200 root=/dev/mmcblk0p3
rootfstype=ext3 mini2440=0tb rootdelay=3 init=/linuxrc
irq: clearing pending status 02000000
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00500000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57
console [ttySAC0] enabled
Memory: 64MB = 64MB total
Memory: 60188KB available (3896K code, 636K data, 116K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
net_namespace: 288 bytes
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
SCSI subsystem initialized
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
NTFS driver 2.1.29 [Flags: R/W DEBUG].
yaffs Aug 24 2009 16:57:57 Installing.
msgmni has been set to 117
io scheduler noop registered (default)
Console: switching to colour frame buffer device 30x20
adc initialized
input: buttons as /class/input/input0
buttons initialized
leds initialized
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
nbd: registered device at major 43
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
dm9000 Ethernet Driver, V1.31
Now use the default MAC address: 08:90:90:90:90:90
eth0: dm9000e at c4804000,c4806004 IRQ 51 MAC: c3908934 (friendly-arm)
usbcore: registered new interface driver zd1211rw
usbcore: registered new interface driver zd1201
Linux video capture interface: v2.00
ovcamchip: v2.27 for Linux 2.6 : OV camera chip I2C driver
usbcore: registered new interface driver ov511
ov511: v1.64 for Linux 2.5 : ov511 USB Camera Driver
Driver 'sd' needs updating - please use bus_type methods
s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V
8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Bad eraseblock 1888 at 0x0ec00000
Bad eraseblock 3186 at 0x18e40000
Bad eraseblock 5363 at 0x29e60000
Creating 4 MTD partitions on "NAND 1GiB 3,3V 8-bit":
0x00000000-0x00060000 : "supervivi"
0x00060000-0x00260000 : "Kernel"
0x00260000-0x40260000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V
8-bit" -- size truncated to 0x3fda0000
0x00000000-0x40000000 : "nand"
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver appletouch
input: s3c2410 TouchScreen as /class/input/input1
s3c2410 TouchScreen successfully loaded
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz).
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
UDA1341 audio driver initialized
failed to get memory region resouce
s3c2410-iis: probe of s3c2410-iis.0 failed with error -2
TCP cubic registered
s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz).
mmc0: new SD card at address b368
mmcblk0: mmc0:b368 SD 993792KiB
mmcblk0: p1 p2 p3
s3c2410-rtc s3c2410-rtc: setting system clock to 2011-07-26 06:16:48 UTC
(1311661008)
Waiting 3sec before mounting root device...
kjournald starting. Commit interval 5 seconds
EXT3 FS on mmcblk0p3, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem).
Freeing init memory: 116K
The following is the environment setting
MINI2440 # prinr tenv
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
ipaddr=10.0.0.111
serverip=10.0.0.4
netmask=255.255.255.0
usbtty=cdc_acm
mtdparts=mtdparts=mini2440-nand:256k@0(u-boot),128k(env),5m(kernel),-(root)
mini2440=mini2440=0tb
bootargs_init=init=/sbin/init
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
${mini2440} ${root_mmc}
${mini2440} ${roo...stripped-down
warning unable to open an initial console
ya actually i have download the filesystem from http://sites.google.com/site/belina76/android-booting and followed the steps given in it. in the filesystemin /dev is empty.. dono who others cud bring up android..
