I try to run Linux with nfs-root from barebox, but the kernel cannot mount
root-filesystem. I've added parts of my "/env/config" and some messages
from booting, which I regarded as being important for my problem.
Does anybody has a hint for me? Did I forget anything in my config?
Kind Regards
Dirk
/env/config:
eth0.ipaddr=192.168.10.200
eth0.serverip=192.168.10.150
eth0.netmask=255.255.255.0
eth0.gateway=192.168.10.254
kernel_loc=tftp
rootfs_loc=net
rootfs_type=jffs2
rootfsimage=rootfs.${rootfs_type}
_______________________________
Boot-Output:
Starting kernel ...
commandline: console=ttySAC0,115200 mini2440=0tbi
ip=192.168.10.200::192.168.10.254:255.255.255.0::: root=/dev/nfs
nfsroot=192.168.10.150:/srv/nfsroot,v3,tcp noinitrd
mtdparts=nand:256k(bareb)
arch_number: 1999
Uncompressing Linux... done, booting the kernel.
dm9000 dm9000: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
IP-Config: Complete:
device=eth0, addr=192.168.10.200, mask=255.255.255.0,
gw=192.168.10.254,
host=192.168.10.200, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=192.168.10.150, rootpath=
VFS: Mounted root (nfs filesystem) on device 0:15.
devtmpfs: error mounting -2
Freeing init memory: 148K
Kernel panic - not syncing: No init found. Try passing init= option to
kernel. See Linux Documentation/init.txt for guidance.
[<c00326d4>] (unwind_backtrace+0x0/0xf4) from [<c0350fa0>]
(panic+0x4c/0x1ac)
[<c0350fa0>] (panic+0x4c/0x1ac) from [<c002d5b0>] (init_post+0xc4/0x140)
[<c002d5b0>] (init_post+0xc4/0x140) from [<c0008430>]
(kernel_init+0xe4/0x120)
[<c0008430>] (kernel_init+0xe4/0x120) from [<c002e878>]
(kernel_thread_exit+0x0/0x8)
Barebox Linux NFS-Root
Have you tried to mount a "default" rootfs via NAND. Are you using the Pengutronix BSP? Which version of Barebox?
It's barebox 2011.07, Kernel 3.0, busybox 1.18.5.
I found out, that root seemed to be mounted.
When I deactivated devtmpfs in Kernel-Config,
I get another message. (No Init found).
(On /sbin/init is a link to busybox.)
gw=192.168.10.254,
VFS: Mounted root (nfs filesystem) on device 0:14.
[<c00326d4>] (unwind_backtrace+0x0/0xf4) from [<c0350b14>]
(panic+0x4c/0x1ac)
[<c0350b14>] (panic+0x4c/0x1ac) from [<c002d5b0>] (init_post+0xc4/0x140)
[<c002d5b0>] (init_post+0xc4/0x140) from [<c00083f0>]
[<c00083f0>] (kernel_init+0xe4/0x120) from [<c002e878>]
Dirk, You seem to be at the "bleeding edge"! I am still working with Barebox 2011.05 and 2.6.39.3. Good luck, Dave
I used buildroot (latest from git) "make mini2440_defconfig" Added Barebox and Kernel3.0 :-) Is it possible, that there is something wrong with my busybox-binary? Kind Regards Dirk
That looks suspect, but it has been over a year since I struggled with cross-compiling Busybox myself. It is suppose to use a default init file, if don't provide one. Dave.
I had a look at LXR.
I found out (main.c from line 677)
Kernel tries several defaults, before it panics.
I'm sure to have "/sbin/init" in my rootfs.
Is there a possibility to debug loading my init?
Kind Regards
Dirk
if (execute_command) {
run_init_process(execute_command);
printk(KERN_WARNING "Failed to execute %s. Attempting "
"defaults...\n", execute_command);
run_init_process("/sbin/init");
run_init_process("/etc/init");
run_init_process("/bin/init");
run_init_process("/bin/sh");
panic("No init found. Try passing init= option to kernel. "
"See Linux Documentation/init.txt for guidance.");
Do you mean, that I need a whole filesystem in /srv/nfsroot ? I just put the rootfs.jffs2 file there. the rootfs.jffs2 contains a "/dev"-directory.
Dirk, you always need the whole root filesystem at the location where you instruct your kernel to NFS-mount. That is how "NFS root filesystem" is working. The rootfs.jffs2 is intended for the NAND flash.
