Hi, I installed Qemu and uboot work well. The only problem is that I dont know how to specify a file system, I tried NFS but it don't work. Can you give me another way to load the file system please. goooo@goooo:~/Bureau/qemu/qemu$ ./mini2440/./mini2440_start.sh Starting in /home/goooo/Bureau/qemu/qemu/mini2440 arm-softmmu/qemu-system-arm -M mini2440 -drive file=/home/goooo/Bureau/qemu/qemu/mini2440/mini2440_snapshots.img,snapshot=on -serial stdio -kernel /home/goooo/Bureau/qemu/qemu/mini2440/uImage_16k -mtdblock /home/goooo/Bureau/qemu/qemu/mini2440/mini2440_nand.bin -show-cursor -usb -usbdevice keyboard -usbdevice mouse S3C: CLK=240 HCLK=240 PCLK=240 UCLK=57 QEMU: ee24c08_init DM9000: INIT QEMU MAC : 52:54:00:12:34:56 QEMU mini2440_reset: loaded default u-boot from NAND QEMU mini2440_reset: loaded override u-boot (size 37600) QEMU mini2440_reset: loaded /home/goooo/Bureau/qemu/qemu/mini2440/uImage_16k (size 2ac000) S3C: CLK=240 HCLK=240 PCLK=240 UCLK=48 S3C: CLK=304 HCLK=304 PCLK=304 UCLK=48 S3C: CLK=304 HCLK=101 PCLK=50 UCLK=48 S3C: CLK=304 HCLK=76 PCLK=38 UCLK=48 S3C: CLK=304 HCLK=76 PCLK=38 UCLK=48 S3C: CLK=405 HCLK=101 PCLK=50 UCLK=48 U-Boot 1.3.2-moko12 (Feb 22 2011 - 22:00:10) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: 64 MiB *** Warning - bad CRC or NAND, using default environment USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 MINI2440 #
Qemu Help
Nobody ? What are the excats step to set up a NFS connection between my Pc et QEmu. I just need the steps and the bootargs. Thanks
I'm not sure about the qemu-part, but you need to pass root=/dev/nfs nfsroot=YOUR_SERVERS_IP:FULL_PATH_TO_ROOTFS ip=dhcp to the kernel google "NFS Diskless client" and you'll find some howtos about the correct command-lines
