hi friends, I got new tiny6410 board from china. Default board installed the qtopia OS. i want to install windowsCE6, so that i create windowsCE6 images on SD card by done following steps... 1) Right click SD-Flasher.exe and select run as administrator 2) Selecte Superboot-20101233.bin file 3) Scan SD Drive and Select SD card in below List 4) Click Relayout Button 5) And then click one more time scan button 6) Finally click Fuse button. 7) open SD card in create Images Folder on root directory 8) Create WindowsCE6 Folder on images Directory 9) Copy FriendlyARM.ini file into a Images Directory 10) Copy bootlogo.bmp,NK.bin,NK.nb0 and NBOOT.nb0 into WindowsCE6 Folder of the SD card 11) Finally Inset Card in tiny6410 boar. Select S2 Switch to SD_BOOT 12) Connect the serial port 13) When on the board. two beep is come and LED flash up and down format but OS not boot. :( in serial port in get "ID ERR" i dont what is problem.. please help friends. // friendARM.ini file content #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action=install OS= WindowsCE6 VerifyNandWrite=yes StatusType = Beeper| LED
