Hi, I have installed Ubuntu on my mini6410 and I am connected on Hyperterminal. The boot stop to calibrate the lcd screen. Here is my problem : I have no lcd screen. How can do to pass this step and dialog with the board via the serial COM ?
Ubuntu on mini6410
mount the rootfs as a loop-device and check if the console is enabled. On my board, I had to change /etc/init/s3c64xx-serial.conf in the file the port is called s3c64somethingsomething -- change it to ttySAC0, add ttySAC0 to /etc/securetty (if not present) and check if /dev/ttySAC0 with 204,64 exists D
Hi, I have installed Ubuntu on my Tiny6410 and there is no any LAN settings, Ethernet does not work. LAN works fine with Qtopia an Windows CE 6.0, but not with ubuntu... How can i setup lan in ubuntu?
Hi DeltaT Following your descriptions, I checked on the Ubuntu came from the DVDs, I don't see any S3C6410* but s3c2410_serial0_conf. I wonder why? May I know what Ubuntu version is it and where did you get it from? Having said that, my Ubuntu works fine as far as I am concerned. The reasons I am still working on this, is because, I have my own Xubuntu (downloaded from Ubuntu repositories). I used the Ubuntu from the DVD (which is working ) as my reference. With of the necessary files relating the touchscreen I know of, I still can't get the touchscreen working in my Xubuntu. Any helps would be appreciated. Cheers! vib
Hi, i got an OK6410 ARM board, in which i had installed ANDROID 2.2 OS. But now i wanna load UBUNTU OS in it. But i am stucked up here as i dont know where and how to begin. So someone help me about this ASAP.
Is OK6410 same as mini6410? If it is, you probably want to take a look on the User's Guide to Mini6410 Linux_041611.pdf. I follow the instructions, it works like a champ.
I HAVE INSTALLED UBUNTU IN MINI6410 AND CONNECTED IN HYPER TERMINAL HERE IS MY PROBLEM I HAVE NO LCD SCREEN BOOTING UBUNTU IN HYPER TERMINAL FOLLOWING DISPLAY HAS APPEARED AND NOT BOOTING FURTHER #0: MINI6410 TCP cubic registered NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 s3c-rtc s3c64xx-rtc: setting system clock to 2000-02-23 23:22:15 UTC (951348135) Freeing init memory: 1408K UBIFS: recovery needed UBIFS: recovery completed UBIFS: mounted UBI device 0, volume 0, name "FriendlyARM-root" UBIFS: file system size: 2056126464 bytes (2007936 KiB, 1960 MiB, 1992 LEBs) UBIFS: journal size: 12517376 bytes (12224 KiB, 11 MiB, 13 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) one_wire_status: 4 TouchDevice: /dev/touchscreen xres = 480, yres = 272 BUT HOW TO CONFIGURED VIA TERMINAL
