Hi, I've just gotten the board and just got the tool chain working. I've read though the material/manuals, etc.. got a handle on the basics. But what I wasn't able to find anywhere is info on the various linux builds (Config Files). I figured out that anything with 7 in it is for the 7" monitor and 35 is for the 3.5" panel, and the config_mini2440_vga1024x768 is for the external VGA. Aside from that could you let me know (1) Before I blow everything away on this, what is on it as a factory fresh board? (I have a G540 [checked] on the side of the box, its a 3.5 LCD touch on the mini2440 board). (2) Any explanation of the different .config file images? i.e. what's the difference between n35 and t35 and what is the qq designation, another board? Thanks config_mini2440_a70 config_mini2440_n35 config_mini2440_t35 config_mini2440_vga1024x768 config_qq2440_a70 config_qq2440_n35 config_qq2440_vga1024x768
New User Stupid Questions on images.
A momentary intelligent thought crossed my brow. I diff'ed the two config files.. there was only one difference between the config_mini_2440_n35 and the config_mini_2440_t35. That difference is the frame buffer drivers, apparently ( CONFIG_FB_S3C2410_N240320 - or - CONFIG_FB_S3C2410_T240320). The *_N240320 is apparently for an 8" 800x480 LCD panel (should have ended the config file with an "80" to stay consistent. Where the _T240320 was set for the 3.5" LCD panel.. otherwise no difference. Hope this helps someone else..
