Hi, I'm sorry, I tried everything but I don't success to change my Qt app font. The issue is that the font size is different on the PC and on the Mini2440. (Not the same font on the Mini2440). On the Mini2440 Qt app seems to use the Courier 10. I have the preinstalled system, and I start Qt app like that : /etc/init.d/rcS export PATH=/opt/Qtopia/bin:$PATH export LD_LIBRARY_PATH=/opt/Qtopia/lib:$LD_LIBRARY_PATH export QTDIR=/usr/local/Trolltech/QtEmbedded-4.6.3-arm export QPEDIR=/usr/local/Trolltech/QtEmbedded-4.6.3-arm export PATH=$QTDIR/bin:$PATH export LD_LIBRARY_PATH=$QTDIR/lib:/usr/local/lib:$LD_LIBRARY_PATH export TSLIB_TSDEVICE=/dev/input/event0 export TSLIB_CONFFILE=/usr/local/etc/ts.conf export TSLIB_PLUGINDIR=/usr/local/lib/ts export TSLIB_CALIBFILE=/etc/pointercal export QT_QWS_FONTDIR=/usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib/fonts export QWS_MOUSE_PROTO="TSLIB:/dev/input/event0 USB:/dev/input/mice" export QWS_SIZE='320x240' echo " " > /dev/tty1 echo "Starting Qt Application" > /dev/tty1 sleep 1 /udisk/qtapp -qws In order to change the font I tried that : - Start the app with "-qws -fn DejaVuSans" - Add this : QWS_DISPLAY=LinuxFB:mmWidth=70:mmHeight=53 - I also tried to change the font in my Qt app But I always have the Courrier 10 font when I run my app. If someone can help me please ?
Cannot change Qt App font
I'm sorry I found my error. By default, the Mini2440 is shipped with Qt preinstalled but there is only one font. So, I add the other font and I put in order to adapt the size font for the Mini2440 (otherwise the font are too small): export QWS_DISPLAY=Transformed:Rot0:mmWidth=69:mmHeight=53 Now, I can choose the police from QtDesigner.
