Hi I want to access to usb port on my mini 2440 , i'm using winCE 6 and visual studio 2008 (C#.net ) . dose any one know how can i connect to usb port and transmit and receive data with it ? i want to send and receive data like serial port . help me please .
Access to usb on mini2440
Hi Dave, Which board are you using? Meaning where did you buy it from? I also sometimes got junk characters from one of my minis. After I replacing the RS232 level translator IC (3232) and all of its capacitors it resolved the problem and I got no more junk characters. MC
i think you misunderstood , i want to connect another device with usb port to my mini 2440 and i want to send data through mini 2440 usb port to another device . how can i access to mini's usb port in C# ?
the host or the slave port ? I mean, you want to use the mini as a PC device ? or you want to talk to a slave device ( like a HID device ) ?
Hi elenor! I'm sorry about my english that is not good! I have the same problem! i searched for resolving the problem! Some link show infor about USB driver on BSP (USB serial, USB RNDIS), if you check 2 driver, driver USB serial will be loaded defalt because the ActiveSyn run when USB plug in. So i try remove USB serial driver, i don't know USB RNDIS was loaded or unloaded! If you can resolve the problem, please help me! Thanks in advance! Regards! markpq
