Where in the datasheet describes paramtry margin_left, margin_right, hsync,
_yres, margin_top, margin_bottom, vsync
for example take
_LCD_DECLARE(
7, /* The 3.5 is quite fast */
240, 21, 25, 6, /* x timing */
320, 2, 4, 2, /* y timing */
40), /* refresh rate */
datasheet http://www.friendlyarm.net/dl.php?file=TD035STED4.pdf
and
[5] = {
_LCD_DECLARE(
7,
240, 1, 26, 5, /* x timing */
320, 1, 5, 9, /* y timing */
60), /* refresh rate */
datasheet http://www.friendlyarm.net/dl.php?file=NL4827HC19.pdf
Could help me understand some code in the Linux kernel
For the TD035STED4 you can find the timing spec on page 13. margin_left=horizontal back porch margin_right=horizontal front porch xres=horizontal active area hsync=horizontal sync pulse width and so on...
But horizontal front porch in datasheet = 10 and horizontal sync pulse
width = 10
In config
LCD_DECLARE(
240, 21, 25, 6, /* xres, margin_right, margin_left, hsync */
320, 2, 4, 2, /* yres, margin_top, margin_bottom, vsync */
That is, horizontal front porch = 25 and horizontal sync pulse width = 6
