Hi, i have a friendly arm mini2440 with display 7" now i have buy a 3.5" but Xorg that go on 7" doesn't work! i start with option mini2440=0tb, the display works, text and image on starting but if i try loading X: root@mini2440:~# X :0.0 -nocursor _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6 _XSERVTransOpen: transport open failed for inet6/mini2440:0 _XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6 X.Org X Server 1.7.4 Release Date: 2010-01-08 X Protocol Version 11, Revision 0 Build Operating System: Linux 2.6.32-29-generic x86_64 Current Operating System: Linux mini2440 2.6.32.11 #1 Wed Mar 30 12:50:36 CEST 2011 armv4tl Kernel command line: console=ttySAC0,115200 mini2440=0tb rootfstype=ext3 root=/dev/mmcblk0p1 rw rootwait Build Date: 04 April 2011 11:57:07AM Current version of pixman: 0.21.4 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.0.log", Time: Sun Dec 14 06:26:53 2036 (==) Using config file: "/etc/X11/xorg.conf" (EE) FBDEV(0): FBIOPUT_VSCREENINFO: Invalid argument (EE) FBDEV(0): mode initialization failed I have read in some posts that it can be a problem of timing, now i use a xorg.conf with many options, initally i used an empty one and i add many option for try: section "ServerLayout" Identifier "XFree86 Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" InputDevice "Keyboard0" "CoreKeyboard" # InputDevice "Touchpad0" "CorePointer" Option "OffTime" "10" EndSection Section "Module" Load "extmod" Load "dbe" Load "fb" Load "fbdev" Load "fbdevhw" Load "mouse" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" EndSection Section "Monitor" Identifier "Monitor0" ModelName "Monitor Model" DisplaySize 240 320 HorizSync 28286 VertRefresh 85.714 EndSection Section "Device" #Option "ShadowFB" "true" Identifier "Card0" Driver "fbdev" Option "fbdev" "/dev/fb0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" EndSection Section "InputDevice" # Change "XkbModel" to "macintosh_old" if you are using # the deprecated adb keycodes. Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" EndSection fbse -i give me: mode "240x320-86" # D: 8.627 MHz, H: 28.286 kHz, V: 85.714 Hz geometry 240 320 240 320 16 timings 115913 21 38 4 4 6 2 accel false rgba 5/11,6/5,5/0,0/0 endmode but i don't know where put all these info... Some one know the solution? PS: I have compiled bitbake 2011.03 jkroby@p3r.info
