Dear Sirs, I am new and from 1 month I have bought the MINI-2440. I have a question about the managing to Bios Startup: The Bios in NAND Flash, starts the Bootloader immediatly. How I can stop the bootloader startup, for example to push space bar at start. I wait answer. Thank you. Regards, Alessio.
Pause bootloader at startup
Why do you want to do that? Some bootloaders has a programmable bootup delay. Some bootloaders has a menu which comes up by default and others you can access by pressing a key while the boot delay is counting down. Which bootloader are you using?
Hi , I also tryed the same, as mentioned in mini2440 doc, while booting from NAND, to stop at boot prompt, push down space bar. But it is not stopping at boot promt and it is loading the kernel. what should i do to get boot promt while booting from NAND? It is a fresh board.
