Hi, The default image of linux worked fine and when I tried to load the boot loader and the image of WinCE 5.0 which comes in the CD (nboot_T35.bin and NK_T35.bin), I see that the touch is inverted i.e. if I try to touch at lower left side of the screen it triggers a touch event as if top right side of the screen was touched. Does any one know why the problem is seen and any solutions to fix it. When I use the 2440test_T35.bin/2440test_X35.bin binaries. Here is the output I see on doing the "5 : Test Touchpanel" test. Not sure if this is the expected behaviour or incorrect behaviour. Stylus Down, please...... count=000 XP=0881, YP=0899 (bottom left) count=001 XP=0108, YP=0893 (bottom right) count=002 XP=0111, YP=0124 (top right) count=003 XP=0920, YP=0119 (top left) Thanks Gurjit...
