Hello, Does anyone have SPI driver for WINCE? The SPI Pins are on the GPIO connector. Thanks.
GPIO SPI Driver
Here are some contributions to them. As it stands, there are probably differences between the "Mini" and "micro" in the pinout. Just once you read through the Forum, through.
There are several ways an ARM-based embedded Linux programming machine. Each programming technique requires a very specific expertise, places special demands on the next to use development tools.
Can anyone please check this SPI driver?
#include <windows.h>
void SPIInit();
void Virtual_Alloc();
#define DLLEXPORT __declspec(dllexport)
#define EXTERNC extern "C"
EXTERNC BOOL VirtualCopy(LPVOID dest, LPVOID src, DWORD size, DWORD flags);
#define SSP_BASE 0xB1900000 // 0x59000000
typedef struct {
unsigned int rSPCON0; // 00
unsigned int rSPSTA0;
unsigned int rSPPIN0;
unsigned int rSPPRE0;
unsigned int rSPTDAT0; // 10
unsigned int rSPRDAT0;
unsigned int rPAD[2];
unsigned int rSPCON1; // 20
unsigned int rSPSTA1;
unsigned int rSPPIN1;
unsigned int rSPPRE1;
unsigned int rSPTDAT1; // 30
unsigned int rSPRDAT1;
}SSPreg ;
bool memoryAlloced = false;
volatile SSPreg *s2440SPI = (SSPreg *)SSP_BASE;
EXTERNC DLLEXPORT void Config_SPI(void);
SPIInit();
s2440SPI->rSPPRE0=199; //baud rate = 6MHZ; PCLK = 60KHZ
s2440SPI->rSPCON0=63; //interrupt Mode, SCK Enabled, Master, CPOL=1,
CPHA=1, TAGD =1
EXTERNC DLLEXPORT int Status_SPI(void);
SPIInit();
int i;
i=s2440SPI->rSPSTA0; //status
return i;
EXTERNC DLLEXPORT int Write_SPI(int data);
SPIInit();
s2440SPI->rSPTDAT0=data; //status
return 0;
EXTERNC DLLEXPORT void Close_SPI(void);
SPIInit();
s2440SPI->rSPPRE0=0; //
s2440SPI->rSPCON0=0; //
// GPIO Virtual alloc
s2440SPI = (volatile SSPreg *) VirtualAlloc(0,sizeof(SSPreg),MEM_RESERVE,
PAGE_NOACCESS);
if(s2440SPI == NULL)
RETAILMSG(1,(TEXT("For s2440SPI: VirtualAlloc faiLED!\r\n")));
else {
if(!VirtualCopy((PVOID)s2440SPI,(PVOID)(SSP_BASE),sizeof(SSPreg),PAGE_READWRITE
| PAGE_NOCACHE ))
RETAILMSG(1,(TEXT("For s2440SPI: VirtualCopy faiLED!\r\n")));
void SPIInit() {
if (!memoryAlloced)
Virtual_Alloc();
memoryAlloced = true;
Hi, Can any one help me in using the SPI driver in the mini2440 for Linux Thanks
Hi Matt Damon,
I´m trying to make a SPI communication, too. It´s been quite hard!
I can access all GPIO´s pins (and ports), including changing their boolean
value. BUT, when I try to send data thought SPI, it doesn´t work!
Can someone help me? (my email: andre.pepino@gmail.com)
My DLL code that I include it on my C# code (some parts I copied from this
and others forums):
#include "StdAfx.h"
#include "SPIDLL.h"
#include "s2440.h"
#include <time.h>
//#include <ceddk.h>
extern "C"
__declspec(dllimport) BOOL VirtualCopy(LPVOID lpvDest, LPVOID lpvSrc,
DWORD cbSize, DWORD fdwProtect);
BOOL APIENTRY DllMain( HANDLE hModule,
DWORD ul_reason_for_call,
LPVOID lpReserved
switch (ul_reason_for_call)
case DLL_PROCESS_ATTACH:
case DLL_THREAD_ATTACH:
case DLL_THREAD_DETACH:
case DLL_PROCESS_DETACH:
break;
return TRUE;
// This is an example of an exported variable
SPIDLL_API int nSPIDLL=0;
// This is an example of an exported function.
SPIDLL_API int fnSPIDLL(void)
return 42;
// This is the constructor of a class that has been exported.
// see SPIDLL.h for the class definition
CSPIDLL::CSPIDLL()
return;
void spiInit();
void Virtual_Alloc_SPI();
void Virtual_Alloc_GPIO();
bool memoryAlloced_GPIO = false;
bool memoryAlloced_SPI = false;
bool SPI_configured = false;
volatile IOPreg *s2440IOP = (IOPreg*) IOP_BASE;
extern "C" _declspec(dllexport) unsigned int WINAPI DLLreadSPI ()
spiInit();
if(s2440SPI->rSPSTA0 & 1 == 1)
return s2440SPI->rSPRDAT0;
return 0;
extern "C" _declspec(dllexport) int WINAPI DLLwriteSPI(unsigned int dado)
if(!SPI_configured)
if (!memoryAlloced_SPI)
memoryAlloced_SPI = true;
if (!memoryAlloced_GPIO)
memoryAlloced_GPIO = true;
//Coloca 101010 a partir do bit 22 do registrador GPECON
s2440IOP->rGPECON = (s2440IOP->rGPECON &~ (63 << 22)) | (42 << 22);
//Função nSS0: É necessária?
//s2440IOP->rGPGCON = (s2440IOP->rGPGCON &~ (3 << 4)) | (3 << 4);
s2440SPI->rSPPRE0 = 99; //Baud Rate padrão
s2440SPI->rSPCON0 = 29; //Ver pg. 505 do datasheet do processador s2440
//Binário 7bits: 0011100
//SPI Mode Select[6,5]: "00" = polling mode
//SCK Enable[4]: "1" = enable
//Master/Slave Select[3]: "1" = master
//Clock Polarity Select[2]: "1" = active low
//Clock Phase Select[1]: "0" = format A
//Tx Auto Garbage Data mode enable[0]: "1" = normal mode
SPI_configured = true;
s2440SPI->rSPTDAT0 = dado;
return 0;
extern "C" _declspec(dllexport) int WINAPI DLLsetPino(char porta, int pino,
bool on)
switch (porta)
case 'A':
s2440IOP->rGPACON = (s2440IOP->rGPACON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPADAT = (s2440IOP->rGPADAT &~ (0x1 << pino));
else
s2440IOP->rGPADAT = (s2440IOP->rGPADAT | (0x1 << pino));
break;
case 'B':
s2440IOP->rGPBCON = (s2440IOP->rGPBCON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPBDAT = (s2440IOP->rGPBDAT &~ (0x1 << pino));
else
s2440IOP->rGPBDAT = (s2440IOP->rGPBDAT | (0x1 << pino));
break;
case 'C':
s2440IOP->rGPCCON = (s2440IOP->rGPCCON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPCDAT = (s2440IOP->rGPCDAT &~ (0x1 << pino));
else
s2440IOP->rGPCDAT = (s2440IOP->rGPCDAT | (0x1 << pino));
break;
case 'D':
s2440IOP->rGPDCON = (s2440IOP->rGPDCON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPDDAT = (s2440IOP->rGPDDAT &~ (0x1 << pino));
else
s2440IOP->rGPDDAT = (s2440IOP->rGPDDAT | (0x1 << pino));
break;
case 'E':
s2440IOP->rGPECON = (s2440IOP->rGPECON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPEDAT = (s2440IOP->rGPEDAT &~ (0x1 << pino));
else
s2440IOP->rGPEDAT = (s2440IOP->rGPEDAT | (0x1 << pino));
break;
case 'F':
s2440IOP->rGPFCON = (s2440IOP->rGPFCON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPFDAT = (s2440IOP->rGPFDAT &~ (0x1 << pino));
else
s2440IOP->rGPFDAT = (s2440IOP->rGPFDAT | (0x1 << pino));
break;
case 'G':
s2440IOP->rGPGCON = (s2440IOP->rGPGCON &~ ( 3 << pino*2)) | ( 1<<
pino*2);
if (!on)
s2440IOP->rGPGDAT = (s2440IOP->rGPGDAT &~ (0x1 << pino));
else
s2440IOP->rGPGDAT = (s2440IOP->rGPGDAT | (0x1 << pino));
break;
return 0;
s2440IOP = (volatile IOPreg *)
VirtualAlloc(0,sizeof(IOPreg),MEM_RESERVE,PAGE_NOACCESS);
if(s2440IOP == NULL)
RETAILMSG(1,(TEXT("For s2440IOP: VirtualAlloc faiLED!\r\n")));
else
if(!VirtualCopy((PVOID)s2440IOP,(PVOID)(IOP_BASE),sizeof(IOPreg),PAGE_READWRITE|
PAGE_NOCACHE ))
RETAILMSG(1,(TEXT("For s2440IOP: VirtualCopy faiLED!\r\n")));
VirtualAlloc(0,sizeof(SSPreg),MEM_RESERVE,PAGE_NOACCESS);
if(s2440SPI == NULL) {
else {
| PAGE_NOCACHE ))
Hello, I developed a Windows CE 6.0 SPI driver and tested it with a SPI temperature sensor tmp125. This driver supports only SPI interface 0, but it would not be difficult to adapt the source code for SPI interface 1. You can download the driver and the test application on my site : http://www.domodom.fr/spip/spip.php?article27&lang=en domdom
hello, @domDom can u tell me how do I understand that Receivable data is available? And when interrupt is generated Data received or sent? and SPSTA Transfer Ready flag becomes set when either data transmission is ready or Receive Buffer is ready. So how do I known which has happened>
