Did someone used Buildroot to generate a image and rootfs for mini6410? I used the kernel source code from here (linux-2.6.36-20101115.tar.gz), but I can't generate the yaffs2 image. Someone can say what I need to do, or if I can use another format?
mini6410 and Buildroot
Hello, it's me again. Well, I compiled the kernel 2.6.36, then generated the rootfs. After, I generated the yaffs2 with the tool provided in the CD. I put the files in the SD card and installed it in the nand. But when I tryied to boot, the following message is showed: ... Uncompressing Linux... done, booting the kernel. Error: unrecognized/unsupported machine ID (r1 = 0x0000065a). Avaliable machine support: ID (hex) NAME 000009d8 MINI6410 Please check your kernel config and/or bootloader.
